[App][$.99] Screen Block (proximity fix)
Did your proximity sensor break? Do you frequently hit "mute" when on phone calls? Well, that happened to my wife's phone, so I made an app that will block the keypad until you slide across it to unlock it (in case you need to hit numbers during a call). To get the block back, just select it from the notification bar.
$.99 https://play.google.com/store/apps/details?id=com.logan.bryan.screenblock
