I think this is day 3 of learning to use an android. I'm confused about how to run the applications. Do they have to be added as shortcuts or widgets to the screen?
Also I "installed" a couple of apps from google play- App 2 SD and a notepad plus an icon set. They don't show up anywhere on my phone and when I return to google play they show up as not installed. It doesn't look like the phone memory is full and the SD card is empty.
The apps that I successfully installed are launcher pro and beautiful widgets.
Thanks for all your help so far
