On newer versions of ES File Explorer (I have v3.0.4) you can get to settings by hitting the menu button on your phone, and then selecting "settings" at the bottom of ES File Explorer. There are no settings at the top.
Several months ago (I guess starting with version 3.0.0) the UI for ES File Explorer made a radical departure from previous versions. Perhaps that's the source of your frustration?
In the upper left corner of ES File Explorer you touch the half globe/phone icon (in the upper left corner of the phone in your screen shot there).
There, you will find settings at the bottom.
It's all part of that HOLO thing.
It almost appears that it is somehow resizing itself off the screen. But not really since the folders look fine.
Stupid questions......have you uninstalled and reinstalled? Have you uninstalled/reinstalled and rebooted before opening the app?
