[APP] LED Timer & Stopwatch
A large clear timer and stopwatch with split function ideal for all timing needs from the kitchen to a large sports timer.
* 1/10ths second (1/100ths available in Pro version)
* Countdown timer (great as a kitchen timer)
* Stopwatch with split
* Up to 99 hours
* Large clear LED display
* Beep feedback
* Auto size to screen
* From the makers of the popular LED Clock
The hours and milliseconds can be turned off allowing the minutes and seconds to use the full screen. Great for the partially sighted and for those wanting to see the display from further away.
One touch control, easy to use interface, beep on key press means these simple functions can be accessed easily! No complicated menus or cluttered layout.
Pro version is also available showing milliseconds to 3 decimal places and removal of advertisements.
As I am a new user, forum rules state I cannot post a link so search the market for 'zabamobile' and you will see the LED Timer & Stopwatch application.
Cheers
Jason
Hi All,
Just wanted to introduce a game I have just published to the Google Play market aimed at children aged 3-7. The concept is simple, bop the moles and avoid the fluffy animals yet engaging through challenges, music and colourful graphics.
Helps to develop hand to eye co-ordination, reflexes and decision making skills making this fun and beneficial to your little ones.
You can download it for free from Google Play at https://play.google.com/store/apps/details?id=com.zabamobile.kidsgame.molebopper
Get Bopping Today!
