I have the latest version of Android available to stock Droid Incredible, 2.3.? I think, and I have had some issues now. It is nothing that breaks the phone, but it is irritating. When ever my phone turns off and back on, it doesnt matter if I turn it off with the button, it runs out of battery or i pull the battery, some Icons on my hone screens disappear and are replaced with default looking Android icons of the little green robot. It only happens with a few and maybe the issue is with the apps? Those apps are 1. Stupid Zombies 2. Stupid Ninjas, 3. Paradise Island. 4.Talking Tom 2. 5. Bunny Mania Lite. Its just odd that it does this I think and I would like to know if there is something I can do the stop this or what is the reason.
I have actually searched the forums and found some post alluding to the idea that this problem affects apps installed on the SD card, is this the likely cause of my issue as well? Mine don't see to revert to an earlier version from what I can tell. How would I tell if this is my issue? And how would I move the apps to internal storage? and even then is there a way to prevent this from happening at all? so that I can use my SD card for storage without this happening?
Thanks!
Thanks!
