App request ?help
Hello guys i am using huawei ascend y300 jelly bean and i have found that there is no built-in option to set different tones for different contacts...
Can anybody tell me an app which allows me to set specific call and sms ringtones for each contact ...
Thank you
I highly recommend you take a look at the free version of Light Flow. You can choose not only different ringtones for calls and SMS from contacts. But also LED notification color (hardware dependent), LED flash rate, reminder tones, reminder frequency, vibration and vibration reminders for each contact.
This goes for contacts or many apps (i.e gmail, calendar, etc). If you want access to more apps, you would need to upgrade to the paid version of Light Flow
https://play.google.com/store/apps/...29uc3VsdGluZy5hbmRyb2lkLmxpZ2h0Zmxvd2xpdGUiXQ..
You should be able to set a different phone ringtone for each contact by selecting the contact. Then tap menu and you should see "Set Ringtone".
Then you only need an app to set text tones. Something like SMS Sounds.
