[APP] Select Input Method Pro
We've developed an android app to access the Select Input Method Dialog with a single click (or a single long press of the Search Key).
Changing keyboards should be simple and straightforward — when you are in the middle of entering text you don't want your thoughts to be disrupted, you just want a different keyboard.
Select Input Method Pro is the name of our app.
There is also a free test version so you can check that the app functions correctly on your Android device (and fulfills your needs and expectations) before purchase: try before you buy...
Whereas the pro (paid-for) version goes immediately to the Select Input Method dialog, the free test version displays four explanatory dialogs before displaying the Select Input Method dialog.
Select Input Method Pro and Select Input Test are both available from Google Play
Unfortunately searching for Select Input Method Pro and/or Select Input Method Test on Google Play lists close to 200 apps (which is a long list to scroll through on a phone).
Search for maddington to find our apps more easily :-)
we are receiving positive feedback that Select Input Method Pro is a good solution to changing keyboards quickly and easily on Android 4.0 Ice Cream Sandwich (ICS).
Icons changed in preparation for release of Select Input Method Trial.
Applies to
  • Select Input Method Pro
  • Select Input Method Test
