raptorjesus
An app called UberMusic is somewhat incredible from one perspective. It is exactly what I seek in terms of design and functionality however, there has been a problem with some cached files (or so I assume) and I wish to delete its cache. However, it's not that simple since if I check the app settings tab then the Clear Cache button is greyed out and it says that this app holds no cache. Now, this isn't realistically possible since after Install/Uninstall about 3 times, nothing has changed. I've tried about 10 different apps (History Remover, CacheMate, App Cache Cleaner and a few more) but none of them even show that UberMusic has cache and so I can't delete it.
Is there any other way because this is driving me crazy and I'm not prepared to factory reset just because of this.
Thanks in advance.
I am on a GS2 running Cyanogen 9.0.
Thanks in advance.
