charles_s
I have found it very helpful to set up my Android using categorized folders on the home screen: System Utilities, GPS-based apps, Audio Streaming, Video Streaming, Browsers, News, Games, Books / Magazines, etc. I also use these to keep links, e. g. for news sites, science blogs, etc. This is easy to set up and very efficient, I have found.
The problem is that it is extremely easy to accidentally delete a whole folder (or sometimes a single icon inside one). An errant straying finger across the screen and a whole folder, which might have twenty icons in it, is gone instantly, with no confirmation prompt, and no clue even as to what has just gone. I can't count how many times this has happened. I then have to try and reconstruct what went missing from memory. Sometimes I will even have to try and figure out which folder it was (yesterday it was Browsers, with Internet, Chrome, Firefox, Dolphin, etc.) It is worse in the case of icons that are just links because these don't even appear in Apps ... they are well and truly gone when deleted.
Why is it, I am wondering, that of the thousands of Android apps out there, there is not one that addresses this ? There are apps to lock apps, contacts, photos, music, display, etc. none of which I need. There are apps to confirm phone calls before you make them. Nothing to lock folders. Nothing, either, that will easily and effectively back up and restore their contents if they are deleted. Nothing to add a confirmation prompt before deletion.
Am I the only Android user in the world who deals with this frustration ?
Would appreciate any input.
Charles
Charles
