[App] Wifi Inspector - Know how is connected!! ( more than 100.000 active installs )
Do you want to know if someone is connected to your wireless network without your permission? Your connection is slow and you suspect that someone are stealing your wifi? Are you afraid that the neighbor may have access to your personal data?
Wifi Inspector is a simple tool to see all the devices connected to our network (both wired and wifi, whether consoles, TVs, pcs, tablets, phones etc ...), giving relevant data such as IP address, manufacturer, device name and MacAddress.
Wifi Inspector also allows to save a list of known devices with custom name and find intruders in less than 30 seconds. This makes it easier for us and you will not need to go checking the data whenever we make a scan.
All this in a clear and simple design that allows us to see that our personal data are safe in a few seconds.
No doubt, Wifi Ispector ALWAYS find ALL connected devices!!
We continue working to improve Wifi Inspector and we greatly appreciate that you share your opinions whether positive or negative. We have almost no reports of problems in the poor ratings (only one star with no comment) This makes difficult that we can improve the application. Please if you have any problems / suggestions do not hesitate to send it to us, in your comment or with email, and we will try to fix it.
Languages
- Spanish
- English
- Italian
- Catalan
For a better experience we recommend Android 4.0 or more.
