aandroiddevelop1
hello guys
i need some help here
im using adt-bundle-windows-x86_64-20140321
and the latest version of eclipse
and developing for android v4.4.2
im learning android development from a site that used the older virsion of eclipse
and developed for older virsion of android
so most of the time the site's orders isnt correct
i wish you could help me on this one
this is my app main activity
the first paragraph is the importent one
this app workes just fine without the line
because of this line the AVD crashes the application and write me an errore massege:
unfortunately, WorkingProject has stopped
what can i do??
help me plz
tnx
Code:
package user.workingproject;
import android.os.Bundle;
import android.support.v4.app.Fragment;
import android.support.v7.app.ActionBarActivity;
import android.view.LayoutInflater;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.view.ViewGroup;
import android.widget.TextView;
public class MainActivity extends ActionBarActivity {
TextView myTextView;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
myTextView = (TextView) findViewById(R.id.myText);
myTextView.setText("New text in TextView");
if (savedInstanceState == null) {
getSupportFragmentManager().beginTransaction()
.add(R.id.container, new PlaceholderFragment())
.commit();
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.main, menu);
return true;
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
* A placeholder fragment containing a simple view.
public static class PlaceholderFragment extends Fragment {
public PlaceholderFragment() {
@Override
public View onCreateView(LayoutInflater inflater, ViewGroup container,
View rootView = inflater.inflate(R.layout.fragment_main, container, false);
return rootView;
Code:
what can i do??
help me plz
tnx
