TheOneGuy
Member
I was curious to know what "Best Wi-Fi Performance" option means in Android and here i received explanation.
What i would like is to set a custom Wi-Fi plan. So when i access app that relies heavily on internet connection, i could easily customize Wi-Fi plan for it. Like Skype application? When you turn screen off while talking to a friend, it disconnects after a few seconds.
Also this is not only for Skype but screen brightness, call volume etc. if you know what i mean.
If this kind of plan is not currently possible, then is there a way to create shortcuts to enable "Best Wi-Fi Performance" with 1 tap from home screen? Or brightness levels 30%, 50% 70% etc.?
So far i can create shortcuts only for sub-menus, but not for sub-options where you need to checkmark stuff.
