RobertCrasmaru
Hello, I am a beginner in android development and I could really use some help. I want to create an application that will do the following things: 1. Posts messages daily (e.g. on 01.21.2016 "The Sun shines", "Cats want to rule the orld" etc." 2. The use can view older posts(e.g. posts from 01.20, 01.19, etc., maybe all posts from the last 30 days). It sounds simple, but here is the thing, I realised that I need some kind of database from which I post this daily posts and where they are saved so the user can see the "old posts". Oh right, I forgot to mention that this application would need permanent internet connection. So, any help? By help I mean some guidelines I could follow in order to create this application. Thank you very much!
