Help Application not auto update
Taga
Hi all
I'm a new member.
I have one issue about auto update android.
When my application has a new update, this is not auto update. And user must update manual.
Please help me find the solution about this issue
Thanks
Taga
You can set it to auto update in the Play Store settings.
Personally I always like to check what an update does before applying it (some updates add things I don't want, in which case I don't want to update), so I always make sure things don't automatically update. But if that's what you want, you just set the Play Store to do that.
If you are the developer of the app and you mean that your app won't update for any user, there is a sticky thread in this forum which tells you where to ask to get a better answer.
Yeah, if an update requires extra permissions then you have to do that manually - and quite rightly so, as you should give the user the option to decline giving it additional permissions they didn't originally sign up to.
I want to my application auto update like that facebook or youtube or something else... I think I mistake some configure to do that. But i don't know how to correct configure
