Application not installed! Root - Camera
maluminse
Im rooted. Stock rom. cmw recovery.
Downloaded htc cam tried to install. Goes through it all and then 'application not installed' at last screen.
Flashed a miui camera. Stock camera still there no mui camera.
Downloaded a miui camera apk. Installing then 'application not installed'.
Im rooted cant I get around this presumed block??
I think your problem is that your trying to mod the stock rom. You probably need a framework.apk that supports the camera apks your trying to use. Possibly a kernal as well because thats what the software runs through to communicate with the hardware. You would be best off reapply the stock camera.apk. Or try just copying the apk to /system/app
