test_tube_baby
Hello Developers,
I am trying to create an app with 3 tabs (which I successfully did so using the tab layout tutorial here Developer Resources | Android Developers ... index.html.
Then I created an Activity for each tab. I am trying to insert a Google Map into the third tab so I have been importing and doing everything by the book.
But when the application runs I get the error: Application xxx has stopped unexpectedly.
When I use DDMS I don't get the error but when I launch the application the screen just stays blank and my logcat says:
CODE: SELECT ALL
07-04 18:01:24.596: WARN/ActivityManager(61): Activity pause timeout for HistoryRecord{406554c8 com.example.cabnow/.CabNow}
I'll show you my code here below.
THANKS IN ADVANCE.
CODE: SELECT ALL
THANKS IN ADVANCE.
