Application to Boost Bluetooth Volume
cmf0106
I purchased a Motorloa HX550, but the volume can be very low on some calls even when at max. Is there a application that will boost incoming volume specifically for a bluetooth headset?
Thanks
I have no idea on the subject but from what I can tell you is that, I have bought a few diffrent blue tooth headsets for work. The cheap ones never worked all that great. I now have a motortrend mt-5000 hedset that I bought at a truck stop for around $90 I think it was. And it works great very clear and loud at times, I have to turn down the volume on it.
If theres no such app you may have to try a diffrent bluetooth.
This wasnt a cheap headset. http://www.amazon.com/Motorola-HX550-Universal-Bluetooth-Headset/dp/B005FPT380
I also had the HX550 volume low issue. I changed phones and the volume was unusable. I contacted HP via chat and that person suggested I factory reset the device. It worked! here are the directions:
Unpair the headset with your phone and perform the following: Press and hold the Call button while turning on the headset to turn these features on/off:
