Apps Application to define default wallpaper
Kreg0
Hi there,
I'm not a developer, so be cool ;)
I would like to know if it's "simple" to create an Android application to set by default the wallpaper "Home" and the wallpaper "screen lock", just with a click for each wallpapers (or why not juste one click for both)
In my compagnie we manage Android under BES10, and unfortunately the wallpaper is not possible on Android (but only on BlackBerry). However I can push application, which is why I need to create this small application :)
To summarize : my application just needs to embedded 2 images and allow with one click to define the default wallpaper for the home and the lockscreen.
What do you think ?
Is it possible for a non-developer? Thank you !
Kreg
