A
Android Question
Guest
hi,
is there an application that have the same idea of the NFC tags that do many different things such as change the settings on your phone, launch applications, check-in to places update social status, or even make phone calls or send text messages automatically. but instead of using NFC it uses the widgets?
for example Make a widget to set your phone up the way you like it when you get to work, or when you get in your car. You can even set an alarm time for a bed widget. You can set individual settings, or combine settings to optimize your phone for your location - at home, at work, in the car, or other places.
