Hello,
I am currently developing a plugin for Eclipse that will check for duplicate attributes in XML layout files for them as styles and I have you present for your review and feedback.
A sample file :
And a part of the result :
How to install it :
The GitHub link https://github.com/Sylvaner/LayoutInspector
A sample file :
Code:
<ScrollView xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
tools:context="com.example.layouttest.MainActivity"
android:id="@+id/container"
android:layout_height="match_parent">
<LinearLayout
android:layout_height="wrap_content"
android:orientation="vertical">
<RelativeLayout
android:layout_height="wrap_content">
<Button
android:id="@+id/find"
android:layout_width="wrap_content"
android:layout_alignParentRight="true"
android:text="Rechercher" />
<EditText
android:layout_alignParentLeft="true"
android:layout_toLeftOf="@+id/find"
android:layout_centerVertical="true"
android:inputType="text"/>
</RelativeLayout>
<TextView
android:text="Une option : "
android:textColor="#FF0000"
android:gravity="center_horizontal"/>
<RadioGroup
android:orientation="horizontal">
<RadioButton
android:text="Oui"
android:layout_width="0dp"
android:layout_weight="0.5"/>
<RadioButton
android:text="Non"
</RadioGroup>
<TextView
android:text="Une autre option : "
<RadioGroup
<RadioButton
android:text="Oui"
<RadioButton
android:text="Non"
</RadioGroup>
<LinearLayout
<TextView
android:text="Un label : "
android:layout_weight="0.33"
android:layout_height="wrap_content"/>
<Spinner
android:id="@+id/spinner"
android:layout_weight="0.66"
</LinearLayout>
<LinearLayout
<TextView
<EditText
android:text="A remplir"
</LinearLayout>
<LinearLayout
<ImageView
android:background="@drawable/ic_launcher"
android:layout_width="128dip"
android:layout_height="128dip"
android:scaleType="fitCenter"/>
<ImageView
<ImageView
</LinearLayout>
<LinearLayout
<Button
android:text="Bouton 1"
<Button
android:text="Bouton 2"
<Button
android:text="Bouton 3"
</LinearLayout>
</LinearLayout>
</ScrollView>
How to install it :
- Download the plugin at this address : https://github.com/Sylvaner/LayoutInspector/raw/master/LayoutInspector_1.1.0.201406211518.jar
- Copy this file in the plugin directory of your Eclipse installation.
- Right click on the folder you want to scan. Layout Inspector -> Inspect this folder.
- See the result in the view.
