Help Applications Don't Work
temelreis
Sorry for mine English.
i have a problem with galaxy s applications, when i open my phone the apps give me error like The application x(x.x.x.) has stopped unexpectedly.please try again.
and then the phone running, but when i try to open apss its give same problem. i tried all Firmwares but its give me same problem again.
i delete all files from my phone like pictures and apss but when i close and open my phone, all i deletefiles are in my phone.
i tried hard reset to much. what shoul i do? please help me?
my phone version is
2.3.6 GINGERBREAD
I hope I'm reading this correctly. Your seeing many apps force close on the Galaxy S. You've tried deleting data and did a hard reset (to much???) but the problem remains. When you say "hard reset" did you go into menu > settings > SD & phone storage and do a factory data reset? If you did a factory data reset and the problem remains, it might be hardware related.
I'm not clear on "I tried all the firmwares" at all. Is the phone rooted and running a non OEM rom? If so, consider re flashing the current ROM or another ROM entirely. Don't forget to wipe at least the Cache and Dalvik cache when your flash any ROM.
Good luck!
Yes, you read correctly, but not many apps force close all apps force close on Galaxy S. The phone shuts down all applications when i open it.
I did hard reset and wipe but it didn't work. So i tried to upgrade firmware version, when i bought it it was 2.1.1 and now is 2.3.6.
I bought Galaxy S about two mounth ago . I started to use it but when i download apps from android market and transfer music from my computer to phone it started to force close all apps. (This all happened about in three days) and I send it warranty service, they cant do anything, they said me we tried evrything but we can't fix it. And they didint change phone.
So i tried fix it alone but its not work, if it might be hardware related why they didint change it.
If anybody knows how to fix this problem, please help me .
And thank you for pastafarian for his answer.
