Help Applications icon from dock replaced
Hi,
I replaced the applications icon from the dock with one of the applications. Earlier, I was able to see all the applications when I click the icon. Now, I have a game icon that replaced the original and don't know how to get it back.
I have GAOSP Beta 3.
Please help me!
Regards,
Sri Harsha.
What launcher are you using?
I'm using GO launcher EX, so i presume that it's similar process.
For ADW (EX) - anyway just use a long press on screen, choose Launcher Actions and Open/close App Drawer.
Now long press on the game icon and remove it (you must see a plus sign). To finish the process, now press and drag the Open/close App Drawer from the home-screen to the dock. It should work.
Hope it helps.
P.S: if you're using another launcher please name it so that I can help you.
How do i know what launcher i am using? When i long press on my screen i only get the following options:
Shortcuts
Custom Shortcuts
Widgets
Folders
Wallpapers
I don't see the Launcher Actions option at all!
Thanks in advance
Shortcuts
Custom Shortcuts
Widgets
Folders
Wallpapers
Thanks in advance
Try going into custom shortcuts. Find something that is called "open/close drawer" or something similar. ;)
