Help Applications to SD Card Error
goon55
Hello, I just upgraded from a D1 to a D2. All my apps came down and installed so all is good there. However, when I go into an application through Settings > Manage Apps and go to Act 1 Video Player for example, the Move to SD card option is available, I select it, then I get the error:
Move Application
Failed to move application
Hit the OK button
Then select the Move to SD card button again and it works.
Thought this might be helpful.
