Apps causing battery drain
baldbull
Are there any apps that one should be aware of that tend to use a lot of battery, specifically, with ICS? I keep installing a lot and notice that my battery randomly is draining faster and I think it's from the apps so I want to know if any are known for battery drainage or they just are in ics.
I think Weatherbug and Facebook drain the battery, or at least they did on my OG Droid like none other. I'm not positive yet on ICS, however I have switched back over to Weather Channel which doesn't appear to drain battery much.
I found the AIM app killed my battery on day one so I uninstalled it. imo instant messenger seems to work a lot better.
