Apps disappearing when using notenoughspace
ned4spd8874
I just started using the app "notenoughspace" and am immediately having problems with it. When I use the app to move a program to the NES partition, it disappears after a reboot. And then I have problems trying to reinstall the app. Eventually I'm able to remove it from the Android applications menu and then able to re-install.
Anyone else notice this while using this app?
