Help Apps dissapeared after using SD Card to do Nandroid restore on another deivce
califauna
Apps dissapeared after using SD Card to restore other S2
Hi all,
I recently did a full nandroid backup on my i9100 onto the external SD card, then took SD card and put into another i9100 and attempted a restore on that device using the nandroid backup from the other (to save time setting up the second device)
When I put the SD card back into the first phone, a bunch of apps are greyed out and can't be launched. They appear in the app manager (in settings) and on the launcher shortcuts screen, but there are no icons at all in the launcher apps grid (where all the apps are listed). When attempting to move them back onto the internal storage, the message is that they 'don't exist' .
Looking in the 'android_secure' folder in the SD card (with the card in a card reader on the PC) I found it to be empty, and its empty in the root explorer in android.
When I did the nandroid recovery on the second phone I also did a 'wipe data', 'wipe cache', and 'wipe dalvik cache' on the device during the install. I assumed this resulted in deleting the apps which were stored on the SD card as well, so I ran a data recovery to find deleted files on the 'android_secure' folder in the SD card and found a bunch of deleted '.asec' files., (though no apks). Putting one of these asec files for one of the lost apps back into the -androi_secure' folder didnt result in the app data being recognised on the device though.
So now Im stuck looking for a way to get these apps and their data back. Would the wipe of the second phone whilst it had the sd card in it have also wiped out the apps on the sd card? Are these .asec files the files which have been wiped?What sort of files should I be looking to recover in order to be able to restore these apps?
LiteROm Custom based on Jelly Bean
64Gb SD Card
Rooted i9100
Thanks for your help.
