APPS for ACE
finally, I purchased my first android phone. samsung galaxy ace!
guys, please help me. suggest apps that are needed or fun for the galaxy ace.
I have installed, apps2sd, juice defender, angry birds, raging thunder lite, fruit slice, ringdroid, and facebook for android.
I would appreciate your suggestions.
thank you!
HI,
since no ones wants to answer lol ill step in,
ok first start facebook for android. forget that , get "flow for facebook" much better i think,
mmm ok for a start get speedx 3d full and free from the market pretty much everyone has this game, plus u can play it with 3d glasses,,,,,it looks mental linked to your flatscreen tv.
emulators,
remember when you was little and went to the arcade and pumped
if you want to see the battery percentage, you can always download Battery Indicator from the android market. It'll put an battery icon with a percentage number on the left of the notification bar.
for my suggestion i think applications like:
ADW launcher - this is cool theme launcher, you can choose what applications to be in the lower screen and hav ability to change the way your desktop moves by the time you swipe...
Wefi - is usable to control your wifi
yxplayer - this is usable in playing xvid, and other format of movies so you dont need to convert movies in mp4 format.
android booster - this is a battery booster which is usable to close applications which is not used..
try this applications...
Hey Friends,
Thanks for such lovely tips for ACE Apps. Appreciate if you can also share the source to download these apps.
Are these all available in 'Android Market', pls confirm.
@ Chismay : Kindly confirm how this emulator works and where from I can down the same.
Thanks.
ok
so for example: if you want gameboy advance on your g-ace
search google "4shared gameboid .apk"
install to your ace, then you will need the bios' you can find these by google VERY EASILY
put the bios on your sd card
when u start gameboid it will ask you to show it where the bios are...just find the bios' file on your sd and select the file,.
gameboid will now run, just download a gameboy advance game-rom from doperoms.com or such add to your sdcard open gameboid select the game and PLAY!!! WHOO HOO
thanx appreciated.
