APPS for newly rooted ace
hello ace users. after 1 year of owning a SGAce, i finally had the courage to root my fone. and it was successful.
May I ask what apps are necessary for me to install now that I rooted my fone?
also what app can I install to force install apps onto the sd card?
thank you. :)
Download SuperUser. I don't know if it's possible to install directly to the sd card but there's an app called App 2 SD.
Superuser would most probable be already on his system,
You should get titanium bakup, adfree and root explorer, these are the essentials.
If you want to use app2sd, it won't work well until you install the Darktremmor's script with it. And you will have to partition your sd card.
Assuming you already have CWM.
Look into xda if you want to make more modifications.
