hi all
i have just got my self a samsung galaxy apollo i5800 , am just wondering how many apps can i keep on the phone memory?i take it they store on the phone memory
and also is there anyway i can install the apps on the phone sd card?
hope this makes sense lol
paul
Currently you can install apps to phone memory only.but with froyo update we will be able to install apps in sd card.but you can use app backup programs.to backup your apps if you run out of space.
Advanced Task Cleaner will also free memory for you, tell you how much memory is being used and how much will be free if apps are shut down, as just because you shut them down, they are still running in the background, much the same as a PC
