If they were moved to the SD using the built in feature of froyo, then yes they can definetly be updated while still on the card. If you are using some other way to do it without froyo, the im not sure it will work.
Hmmm then I have another issue because I am using the froyo feature and they are not updating. When I move them back to the phone they update with no probelm.
