Root Apps not comparable on CM7.2 (Stable)
D
Deleted User
Guest
I Recently started using CM7.2 stable release,
and i am not able to install certain apps rom google play..
I get "This Item is not comparable wit hour device" while trying to install them.
same apps use to work very well on CM7.2 Rc3.
I feel there is some conflict with the country the is set on the device..
please help...
I am having this problem too, mainly live wallpapers, they show as incompatible.
I had this problem in vo-1's RC3 also, but not as sever as now. Since i flashed official version, more and more apps are becoming incompatible.
If i actually get the apk file from friends, the app is actually working flawlessly, its just that it shows incompatible on play store.
Any one has any solution for this???
one thing i noticed is the two apps i tried to install are protected apps..
