Apps not showing in Settings
where are you looking? there are a few places where apps will show up in settings. there's settings>apps and also settings>notifications.
all this depends on what phone you have, put they should be there. maybe a screenshot? or a better explanation on where you are looking for them.
Thanks for your reply. I’m using galaxy 5. I was looking for application manager and clicked on Settings. Quick settings, network connection etc all showed, but the display stopped at Applications, showing only the header and would not scroll up to show Applications Manager. I tried this several times without success. I have just tried again and it has worked perfectly! Sorry!
