okay i am fairly new to android and i would like to put the apps2sd program on my phone so i can save to my sd card. anybody have a easy step by step process to do this?
for FAT32 or Ext2 or both ?...not recommended to make it more than 128MB...
I get it. Thank for helping. ^^
My bad for not specifying, the 128MB (i would say a max of 256MB) will be for the Ext2/3 partition you create.
Fat32 can be up to 16GB (which is the max the phone will support.)
i found the faster way then that go in the market and install Link2SD make sure u have su permission and ur all set i have a 16g sd with over 150+ apps using take5 rom still have 98mb of free space out of 128mb hope i helped do hit THANKS![]()
I can't seem to get root access of my Behold 2. It came with 1.6 from T-Mobile. The ADB process does not work anymore. I can't find a one click app from the market. Any ideas?
go into you recovery mode if that dont work try flashing a new rom take5 or galaxy r12
1 with take5 other with EUGENE373_PDA_FINAL aka r12 take5 is more stable and galaxy is fast take5 has the reg stock camera n video while r12 is just a basic n take5 have vibration while r12 does not i love r12 cause its way faster and u can do ur own lil mods to it take5 sum thing dont work like half the items in recovery while r12 has about 1 or 2 problems its really up 2 up why not give both a test run for a week rite now im using r12 cause im trying to do a lil mod i dont like the white bar =( i miss the take5 status bar =)
I have the BH_MAN_Take5 and the EUGENE373_PDA_FINAL. Which one would you use and why? What are the big differences?
