Root Apps2sd for A87.....?
Hi friends if anybody is using apps2sd scripts on this phone can u guys post the results regarding which script u are using, links to the original thread, how u guys enabled it and all..coz I've seen a lot of guys enquiring about the swap , internal memory and all...
It will be really helpful to all..
Apps2sd is a native gingerbread method to save the files of an apk on the sd card reducing the space occupied on internal memory, but its not that efficient.
Link2sd is a much much more efficient method which can help you install lot more apps without the problem of running out of space for a long time.
But for link2sd a separate partition is required on the sd card.
Swapper is used to 'theoretically' increase ram
its like a page file/virtual memory in windows.
if the background tasks are more and ram is less, then they are shifted to the allotted space and the task goes smoothly.
there are lots of guides on using them, so just google it.
