themonkster
Member
Hello,
I can't seem to get this AppstoSD thing working.
I am using Villian 5.3 ROM
I've formatted my SD Card fully.
Then using the RA-hero-v1.6.2 recovery.
Fomatted the ext partition.
Then converted ext2 to ext3
Installed a couple of apps after booting.
Went back into recovery.
Copied apps and cache to sd card
Re-booted and still the same.
When I install new apps they are using internal strorage.
What is the correct way to sort this out so all my apps are on my sd card ?
