[AppyDroid v1.1 stable public release][free][application][social & media] stable on even old versions of android. not tested on honeycomb or up!.
Hello People.
I had this app posted in the beta testing section but after a few importaint tweaks and updates i feel its stable enough after various testing on many android devices including very basic android phones, sofar it has worked no problems, of course full compatability depends on your phones/devices capability's, a device with flash support is recomended but most of the appyapps work as intended on most mobile devices,
Benifits of using appyDROID.
Well the intended purpouse of using this app is to save you time and bandwidth or internet usage costs, Not only does it make getting to your favorite sites fast and effective, it also should be vastly quicker to do it thanks to the way the browser works. it wont open or retain active windows so you only pay for the usage to download the page, most of us have a data packages nowdays, this app helps reduce how much you need to download in 2 ways, it loads the mobile site, not the full one, it also does this efficently, less bandwidth, easy to reach websites, meaning less searching google or opening favorites, etc saving you time and money.
The home page is also designed to be user freindly as simple as using your own devices home page infact, simply slide and click the appyapp, done! simple as that.
The app also now features a mini browser toolbar, with URL support, so you can quickly add your own url. it now features working back forward and go buttons in addition to the url toolbar, will implement a favorites function soon.
The browser function seems to run way faster than the stock browser, meaning it still retains its bandwidth saving properties during a seperate session
Anyways you can download the public release here, new with browser toolbar!
http://appyphone.hostoi.com/download/AppyDROID.apk
Or scan this QR code on your device for direct downloading.
you can try it in your own web browser here
http://appyphone.hostoi.com/android.html
this version will work depending on your browsers configuration
it may not render how its suposed to designed for the app version, but typicaly this is the page the app loads up, it also wont be as fast as the app version
please let me know what you think!
Here are some pics...
Loading screen.
Icon
Loading in app screenshot.
Loaded screenshot.
Changelog. current v1.1 stable.
Updated App.
Added, back and forward nav buttons.
Added, URL submission bar, with go button
Functional mini web browser.
Added Gsensor support.
Added Black edge gradients [graphical tweak]
Changed Stop app button in menu to reload AppyDROID in the event of a crash!
To quit hit home button on device.
Changed mini browser bar to top of form, Auto hide too bugy at present so made it scroll away when scrolling down, comes back on full top scrolling, Graphical enhancment for a cleaner fullscreen experience.
New Updates from 16/6/2012.
Added heptic feedback on nav buttons.
Added boot up sound.
Server web client updates.
Web app version 1.2 Windows mobile Gui syle.
Added glossy appyapp buttons.
Fixed Loading latency issues where appyapps would at random vanish! on loading.
Few minor graphical tweaks! .
Hello People.
Loading screen.
Icon
Loaded screenshot.
Updated App.
, this could be in app views and simply checking the web version, still i find these numbers astonishing
