Pretty much what the title says, I'm looking to squeeze a 3500mah battery in the OEM extended battery back door, but I'm not positive on the dimensions.
From the research I've been able to gather the 2600mah batteries are 8mm thick and fit the OEM extended door. I'm not quite sure the thickness of the OEM HTC 2150 that typically comes with the OEM extended door.
Can anyone confirm the thickness of the 3500mah?
