Help Are you having this problem.
AV2007LT3
I use folders to store groups of programs related so I can quickly find them. IE new/Weather,etc.
I have noticed on several occasions the folders get stuck and you can't open them, the Icon just flashes red then nothing. If I shutdown/restart my phone they return to normal operation.
Love the phone, this is just annoying.
I am having this problem too! I just started using folders and the one that I made for games wouldn't open today. Weird. I don't no what would cause this, just another weird bug I guess.
I had that issue for a bit, then resolved it by rebooting prior to using or attempting open each newly created folder.
I'm using ADW Launcher & I haven't noticed that problem. However, my GF has the same phone & still uses the stock home screen and has had that issue quite a bit. She fixes it with a reboot.
On a side note, I used to use folders for sorting my apps as well but I found that ADW has a way to sort apps within the app tray. Totally eliminated my need for folders other than for bookmarks. Might be something to look at if you want to get away from folders.
I looked at that launcher earlier this week, but it seems like it only has 5 screens, couldn't figure out how to change that.
It also stinks there is no way to switch launchers on the fly.
It's really simple but to be honest, I accidentally stumbled upon it. :o
Hit "Menu"
Hit "Edit"
That's it! :D
Now you can press the +/X buttons to add/delete each screen individually.
You can also move your screens side to side as well as use the push pin to pick your default screen. Pretty cool actually.
