Root ARHD battery life issue
Marsr
Member
I usually get around 3-5% battery drain overnight, but since flashing ARHD 5.2.0, I've been getting around 15% overnight. I'm basically using the same apps as I always have, so I'm not sure what is causing the issue. Could deleting battery stats fix this, or is this the kernel? There should be new version of ARHD coming out today, with a new kernel, so hopefully that fixes this if it's a kernel issue.
Still getting battery up to 100% for calibration. Charging's really slowed down after around 90%. Using current widget, I normally see 300mA+ when charging, but now it's down to around 70mA, at 93%. Looks like a calibration problem I think.
The last 10% always take longer, and alternatively, it's always the first 100-90% is always the quickest drop too.
Let us know if you see an improvement after calibration.
The new kernel might also sort, but try calibrating first.
Calibrated battery: 6% in 6 hours. Guess that's an improvement, but still not the ~0.5% per hour like I used to get. Maybe it needs some more time to settle in.
Sorry for the late reply, I was on holiday. WiFi wasn't off, but mobile data was. While overseas, my gps wouldn't work with with ARHD 5.2.1 (no fix with 12 satellites), but was fine once I restored to 5.2.0. I think I'll just try leedroid again and so how that goes. Was perfect before, except that with rosie 3d it was a bit sluggish at times.
