Root ARHD oc daemon
Mehta23
Android Expert
Pretty sure I activated this, but its supposed to overclock to 1.15GHz.. But my phone ( reconditioned) only ever reaches 1.075. Is this normal, but should I consider overclocking further and if so how do I do this? I can add screenshots in the morning
now im thinking that OC daemon isnt activated :
You don't need to manually change O/C Daemon settings anymore!
Now my every ROM has Daemon Controller application that allows you to change O/C Daemon settings on the fly!
I dont have a controller app - so Im gonna try rebooting again,
rebooted twice - nothing. followed this tep as in the ARHD post
With Root Explorer go to system/etc/virtuous_oc
but I don't have such a folder in my phone - any help?
Okay, this is an old post, but since I cam across it in Google. I will post the answer for anyone how has the same problem.
When you flash ARHD without Ext4 installed it cannot install the O/C Deamon. The phone than has its clock speed set to 1.075 GHz. Same thing happened to me.
Installing ARHD installs Ext4 in your phone. If you decide to re-flash the same ROM, it will install the O/C Deamon.
