Plenty firmwares over on freaktab.
Instructions :Alright lads I found firmware for mx box mine was bought off eBay and only one firmware would work https://drive.google.com/open?id=0ByVaczQt6FvBdWxBdEh3amVTZVU&authuser=0
Does it have to be 4GB?Instructions :
extract files on to a 4g sd card
put sd card in your box and put a pin in the av hole to hold in secret button and wait it should start installing firmware
Yes I tried connecting keyboard to it but doesn't work. there is no way I can get to any recovery option to ask the device to update from SD card.Have you tried plugging a usb keyboard into it and use the arrows and enter etc
