ROMs ART Runtime Build.Prop Tweaks Updated 8/22/15
  • Start date Start date
D
Deleted User
Guest
Welcome to the ART Runtime Tweaks
Note: these tweaks are experimental DO NOT use on None Android Lollipop or Marhmellow Devices, we do not take responsibility for damages MAKE A BACKUP FIRST!
Now do not remove the dalvik.vm lines we tested it and system will not fulky boot will stay on bootanimation!
Introduction:
What this does is assists the dalvik.vm with art forcing dalvik to run better on the ART Runtime to run dalvik as a Art Virtual Machine this also improves art runtime perfornance and processing etc.
Revision 1:
art.vm.heapstartsize=16m
art.vm.heapgrowthlimit=192m
art.vm.heapsize=512m
art.vm.heaptargetutilization=0.75
art.vm.heapminfree=2m
art.vm.heapmaxfree=8m
art.vm.dexopt-flags=m=v,o=y
Thus tweak will help art to run smoothly i have built and tested this
