Ascend G300, Backup without touchscreen?
Roseweave
A pin is gone on the board of the device so the touch screen can no longer operate.
Basically it looks like my device isn't interacting with the PC Suite. I think it's stuck in mass media mode, though at the same time I can't even see any files.
Is there any way to recover it? Like to force it into that mode, or maybe to root it so I get into recovery mode?
It says "Android SIngle Sooner ADB device" was successfully installed if I hold down the volume button while booting up, then connect it. Does this give me a back door? What do I do?
I can also get into the recover menu no problem. Is there something I can put on the SD card to get this to work?
