Apps [ASK]Create Layout Android
hidayat_io
Hi guys,
I'm newbie here that still starting to learn android programing. I'm gonna create some apps with layout like this :
There is 4 section, i know no.4 is use Action Bar. Section 1 & 2 use Listview.
I'm gonna ask :
1. How to split section 1 and section 2, is this use 2 Listview layout ?
2. What component use to split section 1 & 2 with section 3 ?
Maybe if there is kindly people here that can help me please, or even give me some code to do this.. :D
Thank you before guys. :)
This layout can be writen with 3 LinearLayout's. Like this:
Code:
<LinearLayout
android:layout_height="match_parent"
android:orientation="horizontal">
<LinearLayout
android:layout_width="0dp"
android:orientation="vertical"
android:weight="1"
<!-- ListView 1 and 2 here -->
</LinearLayout>
<LinearLayout
android:weight="1"
<!-- ListView 3 here -->
</LinearLayout>
Code:
<LinearLayout
<LinearLayout
android:weight="1"
</LinearLayout>
<LinearLayout
android:weight="1"
</LinearLayout>
Thank you so much dude.. i'll try it :)
If there can be big amounts of data - then this must be ListViews. If data of these layouts contains limited rows - this can be LinearLayout or RelativeLayout.
Thanks guys you always help me, and again i need you help please.
i wanna create some input form like bellow : when i press ADD on Action Button so this Form Activity should come up.
How to add Close button in Top Left and Save in Top Right , is this use Action Bar ?
And if i see this form doesn't have Back button i think it's a independent activity without any parent.
Is i correct ?
