Apps ASNE - library for simple social networks integration
gorbin
I develop library to simplify integration with social networks ASNE. Just add dependency and you will integrate SDK. I don't need to understand "How it works?" for every social network, download SDK or use some libraries for OAuth and make http calls by yourself. ASNE should makes your life easier. But now I need help from Android developers community, maybe some improvements or at least tests?
GitHub repo - https://github.com/gorbin/ASNE
Short description:
If you want to integrate your application with multiple social networks just choose ASNE modules and add them to your project. You just need to: add module, build SocialNetworkManager and configure your AndroidManiferst. ASNE contains common interface for most popular social networks, but you can easily make module for another.
ASNE contains modules for social networks:
  • Twitter
  • LinkedIn
  • Facebook
  • Google Plus
  • Vkontakte
  • Odnoklassniki
ASNE got almost all necessary requests to social networks
  • Login
  • Configure necessary permissions
  • Get Access Token
  • Get current person social profile
  • Get social profile of user by id
  • Get social profile for array of users
  • Get detailed user profile
  • Share message
  • Share photo
  • Share link
  • Request Share dialog with message/photo/link
  • Check is user(by id) is friend of current
  • Get list of Friends
  • Adding friends by id
  • Remove friend from friend list
  • Any request to chosen social network - you got SDK
I hope it would be useful. At least I use it in 2 commercial project - all works fine!
Tnx for your reply...
