Help assets folder not acessing database file on real device
Here is my script
For some reason it works on the emulator but when i run it on the phone it does not access the database file. This an example based on the book beginning android development.
method tried to fix problem
1. I added the new table called android_meta
2. I tried altering the database and trying outStream.flush
3. I think from reading the log cat that there could be a problem with my version of sq lite. Should i upgrade my phone.
Could some please show me how i can fix my database I would be very appreciative.
Here is the logcat
06-19 17:55:33.124: E/SqliteDatabaseCpp(547): sqlite3_open_v2("nullMyDB", &handle, 1, NULL) failed
06-19 17:55:33.144: E/SQLiteDatabase(547): Failed to open the database. closing it.
06-19 17:55:33.144: E/SQLiteDatabase(547): android.database.sqlite.SQLiteCantOpenDatabaseException: unable to open database file
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.database.sqlite.SQLiteDatabase.dbopen(Native Method)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:1013)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:986)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:962)
06-19 17:55:33.144: E/SQLiteDatabase(547): at alex.android.test.db.DBAdapter$DatabaseHelper.checkDataBase(DBAdapter.java:107)
06-19 17:55:33.144: E/SQLiteDatabase(547): at alex.android.test.db.DBAdapter$DatabaseHelper.<init>(DBAdapter.java:49)
06-19 17:55:33.144: E/SQLiteDatabase(547): at alex.android.test.db.DBAdapter.<init>(DBAdapter.java:40)
06-19 17:55:33.144: E/SQLiteDatabase(547): at alex.android.test.db.AndroidtestdbActivity.onCreate(AndroidtestdbActivity.java:26)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.app.Activity.performCreate(Activity.java:4465)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1049)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1920)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1981)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.app.ActivityThread.access$600(ActivityThread.java:123)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1147)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.os.Handler.dispatchMessage(Handler.java:99)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.os.Looper.loop(Looper.java:137)
06-19 17:55:33.144: E/SQLiteDatabase(547): at android.app.ActivityThread.main(ActivityThread.java:4424)
06-19 17:55:33.144: E/SQLiteDatabase(547): at java.lang.reflect.Method.invokeNative(Native Method)
06-19 17:55:33.144: E/SQLiteDatabase(547): at java.lang.reflect.Method.invoke(Method.java:511)
06-19 17:55:33.144: E/SQLiteDatabase(547): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
06-19 17:55:33.144: E/SQLiteDatabase(547): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
06-19 17:55:33.144: E/SQLiteDatabase(547): at dalvik.system.NativeStart.main(Native Method)
06-19 17:55:33.144: V/db log(547): database does't exist
06-19 17:55:33.204: D/AndroidRuntime(547): Shutting down VM
06-19 17:55:33.204: W/dalvikvm(547): threadid=1: thread exiting with uncaught exception (group=0x409c01f8)
06-19 17:55:33.244: E/AndroidRuntime(547): FATAL EXCEPTION: main
06-19 17:55:33.244: E/AndroidRuntime(547): java.lang.RuntimeException: Unable to start activity ComponentInfo{alex.android.test.db/alex.android.test.db.AndroidtestdbActivity}: java.lang.NullPointerException
06-19 17:55:33.244: E/AndroidRuntime(547): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1956)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1981)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.app.ActivityThread.access$600(ActivityThread.java:123)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1147)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.os.Handler.dispatchMessage(Handler.java:99)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.os.Looper.loop(Looper.java:137)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.app.ActivityThread.main(ActivityThread.java:4424)
06-19 17:55:33.244: E/AndroidRuntime(547): at java.lang.reflect.Method.invokeNative(Native Method)
06-19 17:55:33.244: E/AndroidRuntime(547): at java.lang.reflect.Method.invoke(Method.java:511)
06-19 17:55:33.244: E/AndroidRuntime(547): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
06-19 17:55:33.244: E/AndroidRuntime(547): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
06-19 17:55:33.244: E/AndroidRuntime(547): at dalvik.system.NativeStart.main(Native Method)
06-19 17:55:33.244: E/AndroidRuntime(547): Caused by: java.lang.NullPointerException
06-19 17:55:33.244: E/AndroidRuntime(547): at alex.android.test.db.DBAdapter$DatabaseHelper.copyDataBase(DBAdapter.java:88)
06-19 17:55:33.244: E/AndroidRuntime(547): at alex.android.test.db.DBAdapter$DatabaseHelper.<init>(DBAdapter.java:54)
06-19 17:55:33.244: E/AndroidRuntime(547): at alex.android.test.db.DBAdapter.<init>(DBAdapter.java:40)
06-19 17:55:33.244: E/AndroidRuntime(547): at alex.android.test.db.AndroidtestdbActivity.onCreate(AndroidtestdbActivity.java:26)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.app.Activity.performCreate(Activity.java:4465)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1049)
06-19 17:55:33.244: E/AndroidRuntime(547): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1920)
06-19 17:55:33.244: E/AndroidRuntime(547): ... 11 more
Here is the script that is meant to upload the databae files data
try {
String destPath = "/data/data/" + getPackageName() + "/databases/MyDB";
File f = new File(destPath);
if (!f.exists()) {
CopyDB( getBaseContext().getAssets().open("mydb"),
new FileOutputStream(destPath));
} catch (FileNotFoundException e) {
e.printStackTrace();
} catch (IOException e) {
public void CopyDB(InputStream inputStream, OutputStream outputStream)
throws IOException {
//---copy 1K bytes at a time---
byte[] buffer = new byte[1024];
int length;
while ((length = inputStream.read(buffer)) > 0) {
outputStream.write(buffer, 0, length);
inputStream.close();
outputStream.flush();
outputStream.close();
public class DBAdapter {
public static final String KEY_ROWID = "_id";
public static final String KEY_NAME = "name";
public static final String KEY_EMAIL = "email";
private static final String TAG = "DBAdapter";
private static final String DATABASE_NAME = "MyDB";
private static final String DATABASE_TABLE = "contacts";
private static final int DATABASE_VERSION = 2;
private static final String DATABASE_CREATE =
"create table contacts (_id integer primary key autoincrement, "
+ "name text not null, email text not null);";
private final Context context;
private DatabaseHelper DBHelper;
private SQLiteDatabase db;
public DBAdapter(Context ctx)
this.context = ctx;
DBHelper = new DatabaseHelper(context);
private static class DatabaseHelper extends SQLiteOpenHelper
DatabaseHelper(Context context)
super(context, DATABASE_NAME, null, DATABASE_VERSION);
@Override
public void onCreate(SQLiteDatabase db)
try {
db.execSQL(DATABASE_CREATE);
} catch (SQLException e) {
@Override
public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion)
Log.w(TAG, "Upgrading database from version " + oldVersion + " to "
+ newVersion + ", which will destroy all old data");
db.execSQL("DROP TABLE IF EXISTS contacts");
onCreate(db);
//---opens the database---
public DBAdapter open() throws SQLException
db = DBHelper.getWritableDatabase();
return this;
//---closes the database---
public void close()
DBHelper.close();
//---insert a contact into the database---
public long insertContact(String name, String email)
ContentValues initialValues = new ContentValues();
initialValues.put(KEY_NAME, name);
initialValues.put(KEY_EMAIL, email);
return db.insert(DATABASE_TABLE, null, initialValues);
//---deletes a particular contact---
public boolean deleteContact(long rowId)
return db.delete(DATABASE_TABLE, KEY_ROWID + "=" + rowId, null) > 0;
//---retrieves all the contacts---
public Cursor getAllContacts()
return db.query(DATABASE_TABLE, new String[] {KEY_ROWID, KEY_NAME,
KEY_EMAIL}, null, null, null, null, null);
//---retrieves a particular contact---
public Cursor getContact(long rowId) throws SQLException
Cursor mCursor =
db.query(true, DATABASE_TABLE, new String[] {KEY_ROWID,
KEY_NAME, KEY_EMAIL}, KEY_ROWID + "=" + rowId, null,
if (mCursor != null) {
mCursor.moveToFirst();
return mCursor;
//---updates a contact---
public boolean updateContact(long rowId, String name, String email)
ContentValues args = new ContentValues();
args.put(KEY_NAME, name);
args.put(KEY_EMAIL, email);
return db.update(DATABASE_TABLE, args, KEY_ROWID + "=" + rowId, null) > 0;
