Assets Managing-Scanning tool.
lisq
Hi All:smokingsomb:
I wont to make a list (database) of assets, which would be mostly hardware. I need to have a number of fields like Serial #, Unit Type , Notes, Internal # and so on each entry, so I can query the database on each of them. In audition I would like to be able to have barcode attached to each product on the list so whenever I need to know details about product all I need to do is scan barcode with my smartphone. Last but not least is to be able to have that sync between 5 smartphones so all team can use and update the database.
So is there an app that will do that?
I looked on my own and the closest I got was with "Scanpet", problem with this one is that it would not sync with other mobiles.
Thanks in advance.
