I have a Galaxy Tab S2 running the latest Android available for it. We purchased a Lava TL-002 SimulCharge USB adapter (http://www.lavalinkstore.com/catalog/index.php?main_page=product_info&products_id=74) and a USB Ethernet adapter. We plugged everything together and plugged the ethernet adapter into a router and it got a IP address through DHCP and worked great. We then tried to set a static IP address and it will NOT work. No static IP address we set works but DHCP works fine.
We tried setting a simple 192.168.1.10 for the tablet and then a 192.168.1.20 for a PC and we could not ping back and forth. We then turned on DHCP and the tablet got a 192.168.1.100 and the PC got 192.168.1.101 and we could ping.
For our application we do not want a router, we want hard coded IP addresses. Has anyone heard of this limitation or have any idea where I would go for help? This is a stock tablet with all updates done (OS updates) and no applications downloaded (no GMail account even added). We have tried multiple USB -> Ethernet adapters (USB 2, 3, 10/100, gig, etc) all with the exact same results. We have tried multiple cables and switches. I cannot fault the Lava adapter since it works fine with DHCP so I'm assuming its a issue with the Android OS itself.
Any ideas?
-Allan
Any ideas?
-Allan
