Assigning a Homescreen to a Widget
Phienyx
Does anyone know of an app that allows you to create widgets that link directly to any of your other homescreens?
Is it possible to assign a homescreen to a widget so that when you touch the widget, it brings you directly to the assigned homescreen?
I've had a quick scan and I can't see anything. However, some alternative launchers can do this via shortcuts. I'm using Apex Launcher at the moment and it has the ability to do this. Is that an option?
Go Launcher EX screen indicators also serve as shortcuts to specific screens
I am using Go Launcher Ex and I would prefer to stick with that because of the time I've invested into getting everything set up the way I like with it.
I would think that if I can use the indicators to go to specific screens, there would be a way to assign this to a widget as well....somehow.
