Apps assistance needed on an android project
Hi, I’m a developer from Nigeria and I need your assistance on a project I’m working on. It’s a project where I’m to develop a mobile application using the android framework that utilizes the phone’s dialer function to check the airtime credit balance on each sim card of a multiple sim phone (up to 4 sims), pull the balance from screen response, save it on the app and send via HTTP POST to url. For added points repeat this task using java mobile framework. Note: Settings area for Url, balance checking codes, key and network SIM slot (i.e. SIM 1 = MTN…) is necessary. Required post string values: gsmstatus, gsmsim, gsmbal, key etc.
The major issues I’m having is the “Star” and “Hash” button function on the application and I really need it for the application to work successfully. Any assistance from you would be very much appreciated.
my email is coad_muzik@yahoo.com
What are your issues, and can you provide code to illustrate the problems you are having?
